SDK download
SDK download
johnteng00
SDK download
johnteng00
Hi guys,
Could anyone tell me where I can download the old sdk for revit 2010-2015?
Thank you.
John
jeremytammik
Why in heaven's name would you want that?
It only contains documentation and samples.
All the code you need to execute your add-in in any version of Revit is contained in the Revit executable installation itself, in the Revit API assemblies.
The old documentation is of very little use to you, except for informational purposes.
I cannot image why you would want it.
Jeremy Tammik
Developer Technical Services
The Building Coder
johnteng00
Ok, I know now. Just want to know how to develop the addin for revit 2015 if I don't have the dlls.
Thank you for your reply.
John
jeremytammik
To compile for Revit 2015, all you need are the Revit 2015 .NET API assemblies.
As a minimum, you need RevitAPI.dll and RevitAPIUI.dll. They are referenced when compiling your add-in DLL.
To run and test an add-in for Revit 2015, youalso need to have Revit 2015 itself installed.
The SDK will not help you in the least with any of those two steps.
If you are absolutely sure that all the Revit 2015 API functionality used by your Revit 2015 add-in is also provided by the Revit 2016 or 2017 .NET API, you can also use those .NET API assembly DLL.
Jeremy Tammik
The Building Coder
Just found that there are NuGet packages for all versions (RevitAPI.dll,RevitAPIUI.dll,AdWindows.dll,UIFramework.dll). I love it !
