Message 1 of 11
10:49 AM
Hi all - I'm new to the API and C# and would really appreciate some help. I'm trying to use IUpdater in a macro that automatically starts when a project opens. Is this possible?
So far, I used Macro Manager / Create to set up some boilerplate. Then I pasted in Autodesk's WallUpdater example code (link) into 'public partial class ThisDocument'.
I figured out how to run code on project startup by calling it from the boilerplate's 'private void Module_Startup'. But I haven't had any luck calling WallUpdater.
My code is below. Any ideas or sample code would be highly appreciated. Thanks
Dave
using System; using Autodesk.Revit; using Autodesk.Revit.DB; using Autodesk.Revit.UI.Selection; using Autodesk.Revit.UI; using Autodesk.Revit.Attributes; using System.Collections.Generic; using System.Linq; namespace test { [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)] [Autodesk.Revit.DB.Macros.AddInId("redacted")] public partial class ThisDocument { private void Module_Startup(object sender, EventArgs e) { TaskDialog.Show("hello","this pops up when you open the project"); } private void Module_Shutdown(object sender, EventArgs e) { } #region Revit Macros generated code private void InternalStartup() { this.Startup += new System.EventHandler(Module_Startup); this.Shutdown += new System.EventHandler(Module_Shutdown); } #endregion public class WallUpdaterApplication : Autodesk.Revit.UI.IExternalApplication { public Result OnStartup(Autodesk.Revit.UI.UIControlledApplication application) { // Register wall updater with Revit WallUpdater updater = new WallUpdater(application.ActiveAddInId); UpdaterRegistry.RegisterUpdater(updater); // Change Scope = any Wall element ElementClassFilter wallFilter = new ElementClassFilter(typeof(Wall)); // Change type = element addition UpdaterRegistry.AddTrigger(updater.GetUpdaterId(), wallFilter, Element.GetChangeTypeElementAddition()); return Result.Succeeded; } public Result OnShutdown(Autodesk.Revit.UI.UIControlledApplication application) { WallUpdater updater = new WallUpdater(application.ActiveAddInId); UpdaterRegistry.UnregisterUpdater(updater.GetUpdaterId()); return Result.Succeeded; } } public class WallUpdater : IUpdater { static AddInId m_appId; static UpdaterId m_updaterId; WallType m_wallType = null; // constructor takes the AddInId for the add-in associated with this updater public WallUpdater(AddInId id) { m_appId = id; m_updaterId = new UpdaterId(m_appId, new Guid("FBFBF6B2-4C06-42d4-97C1-D1B4EB593EFF")); } public void Execute(UpdaterData data) { Document doc = data.GetDocument(); // Cache the wall type if (m_wallType == null) { TaskDialog.Show("hello", "world"); } if (m_wallType != null) { TaskDialog.Show("hello", "world"); } } public string GetAdditionalInformation() { return "Wall type updater example: updates all newly created walls to a special wall"; } public ChangePriority GetChangePriority() { return ChangePriority.FloorsRoofsStructuralWalls; } public UpdaterId GetUpdaterId() { return m_updaterId; } public string GetUpdaterName() { return "Wall Type Updater"; } } } }
