IUpdater in a project macro on startup
不适用
2,250 次查看
10 条回复
1 条消息(共 11 条)
不适用
Hi all - I'm new to the API and C# and would really appreciate some help. I'm trying to use IUpdater in a macro that automatically starts when a project opens. Is this possible?
So far, I used Macro Manager / Create to set up some boilerplate. Then I pasted in Autodesk's WallUpdater example code (link) into 'public partial class ThisDocument'.
I figured out how to run code on project startup by calling it from the boilerplate's 'private void Module_Startup'. But I haven't had any luck calling WallUpdater.
My code is below. Any ideas or sample code would be highly appreciated. Thanks
Dave
using System;
using Autodesk.Revit;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI;
using Autodesk.Revit.Attributes;
using System.Collections.Generic;
using System.Linq;
namespace test
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    [Autodesk.Revit.DB.Macros.AddInId("redacted")]
		private void Module_Startup(object sender, EventArgs e)
			TaskDialog.Show("hello","this pops up when you open the project");
		private void Module_Shutdown(object sender, EventArgs e)
		#region Revit Macros generated code
		private void InternalStartup()
			this.Startup += new System.EventHandler(Module_Startup);
			this.Shutdown += new System.EventHandler(Module_Shutdown);
		#endregion
		public class WallUpdaterApplication : Autodesk.Revit.UI.IExternalApplication
			public Result OnStartup(Autodesk.Revit.UI.UIControlledApplication application)
				// Register wall updater with Revit
				WallUpdater updater = new WallUpdater(application.ActiveAddInId);
				UpdaterRegistry.RegisterUpdater(updater);
				// Change Scope = any Wall element
				ElementClassFilter wallFilter = new ElementClassFilter(typeof(Wall));
				// Change type = element addition
				UpdaterRegistry.AddTrigger(updater.GetUpdaterId(), wallFilter, Element.GetChangeTypeElementAddition());
				return Result.Succeeded;
			public Result OnShutdown(Autodesk.Revit.UI.UIControlledApplication application)
				UpdaterRegistry.UnregisterUpdater(updater.GetUpdaterId());
		public class WallUpdater : IUpdater
			static AddInId m_appId;
			static UpdaterId m_updaterId;
			WallType m_wallType = null;
			// constructor takes the AddInId for the add-in associated with this updater
			public WallUpdater(AddInId id)
				m_appId = id;
				m_updaterId = new UpdaterId(m_appId, new Guid("FBFBF6B2-4C06-42d4-97C1-D1B4EB593EFF"));
			public void Execute(UpdaterData data)
				Document doc = data.GetDocument();
				// Cache the wall type
				if (m_wallType == null)
					TaskDialog.Show("hello", "world");
				if (m_wallType != null)
			public string GetAdditionalInformation()
				return "Wall type updater example: updates all newly created walls to a special wall";
			public ChangePriority GetChangePriority()
				return ChangePriority.FloorsRoofsStructuralWalls;
			public UpdaterId GetUpdaterId()
				return m_updaterId;
			public string GetUpdaterName()
				return "Wall Type Updater";
0 个赞
已接受的解答 (1)
2,251 次查看
10 条回复
回复 (10)
2 条消息(共 11 条)
jeremytammik
Welcome to the Revit API!
You should probably not start messing around with this directly in OnStartup.
The system will not work until the Revit application has been fully initialised first, i.e., until the ApplicationInitialized has been called:
https://www.revitapidocs.com/2020/f35ba9fc-0b6b-4284-60eb-91788761127c.htm
I also think that the updater is associated with a specific document.
Consequently, you should probably wait until a document is available, i.e., until the DocumentOpened event has been called:
https://www.revitapidocs.com/2020/7e5bc7a1-0475-b2ec-0aec-c410015737fe.htm
How about starting with a working sample first, and understanding the system in a bit more depth before rolling your own?
Here are some samples and discussion of DMU:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.31
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
0 个赞
3 条消息(共 11 条)
不适用
Thanks very much Jeremy. All the samples I've found appear to be written as add-ins. Do you happen to know where I can find a sample of IUpdater in a macro?
0 个赞
4 条消息(共 11 条)
jeremytammik
Yes, actually, and surprisingly, I do:
https://thebuildingcoder.typepad.com/blog/2014/02/wrangling-revisions-with-ruby.html
Jeremy Tammik
The Building Coder
0 个赞
5 条消息(共 11 条)
不适用
Hi Jeremy - That's a bit too complex for me to follow at this point, especially in Ruby. I was hoping to find an rvt with a vanilla C# IUpdater macro embedded (similar to the SDK Revit_Macro_Samples.rvt). Oh well. Thanks again!
Dave
0 个赞
6 条消息(共 11 条)
jeremytammik
Yup, see what you mean. Searched the blog again and found none so far. Sorry. It is probably awfully simple. Sorry I don't have time right now to put it together for you myself...
Jeremy Tammik
The Building Coder
0 个赞
7 条消息(共 11 条)
不适用
0 个赞
8 条消息(共 11 条)
不适用
已接受的解答
I got it working using the code from boostyourbim linked above. The steps I followed:
1. Use MacroManager to create a new C# module.
2. Edit the new module in SharpDevelop.
3. Add RegisterUpdater() to Module_Startup as follows:
	RegisterUpdater();
4. Add UnregisterUpdater() to Module_Shutdown as above.
5. Just below the boilerplate #endregion, add the boostyourbimcode :
public class FamilyInstanceUpdater : IUpdater
public void RegisterUpdater()
public void UnregisterUpdater()
Make sure FamilyInstanceUpdater, RegisterUpdater, and UnregisterUpdater are inside the scope of ThisDocument.
For testing, I found it handy to replace boostyourbim's Execute code with:
	TaskDialog.Show("Revit","hello");
6. Save and hit F9 to build the macro. Check the MacroManager to see if the build was successful. For some reason, the build occasionally fails for me. I've found that having AssemblyInfo.cs open in SharpDevelop helps. No idea why.
At this point, the macro should be working. Any time you draw an element, you'll get a little popup that says 'hello'.
If you close your project with a successfully built macro, the macro will run automatically the next time you open the project.
I'm sure lots of improvements can be made. For instance, Jeremy recommended using DocumentOpened. And my version currently works for columns and beams, but not for walls. Any input would be appreciated.
Meanwhile, thanks very much to Jeremy for taking a look and to boostyourbim for their code. Hope this helps someone.
9 条消息(共 11 条)
jeremytammik
Thank you very much for your perseverance, successful research and sharing the solution.
I am preparing a blog post from it, if I may.
You say, my version currently works for columns and beams, but not for walls.
Well, you have implemented something called a FamilyInstanceUpdater, you say.
Beams and columns are family instances, and walls are not.
That sounds like a probable cause to me.
You can probably expend your FamilyInstanceUpdater to include Wall objects as well as FamilyInstance objects.
If you do so, please rename it appropriately, for your own sanity's sake.
Jeremy Tammik
The Building Coder
0 个赞
10 条消息(共 11 条)
jeremytammik
For instance, you might change the name and definition of `familyInstanceFilter` from `new ElementClassFilter( typeof( FamilyInstance ) )` to something like this:
  ElementFilter f = new LogicalOrFilter(
    new ElementClassFilter(typeof(FamilyInstance)),
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
0 个赞
11 条消息(共 11 条)
jeremytammik
