Load a shared parameter through the API
danail.momchilov
Message 1 of 1
danail.momchilov
Hello, All. I am wondering on what is the best way to load a shared parameter in a file, using the API? I have been studying Python and experimenting with the API for not more than a few months now. I have been working on several scripts. One of them reads the Family and Type names for certain categories and then copies the values as strings to newly created parameters, that can be used in schedules for filtering. It is doing something similar for Links - by reading their names, name of the file and name of the site. I am generally really happy with the way it works, I simply want to check whether those parameters are loaded and in case they are not, to load them 🙂 Thanks in advace! Here is the script:
# Import from Autodesk API
from Autodesk.Revit.DB import FilteredElementCollector, BuiltInCategory, ElementMulticategoryFilter, Transaction
from System.Collections.Generic import List
# Define short variable for current document
doc = __revit__.ActiveUIDocument.Document
# Filter multiple categories, reffering to non system families
category_list = [BuiltInCategory.OST_PlumbingFixtures, BuiltInCategory.OST_Furniture, BuiltInCategory.OST_Windows, BuiltInCategory.OST_Doors]
filter_list = List[BuiltInCategory](category_list)
filter = ElementMulticategoryFilter(filter_list)
category_collector = FilteredElementCollector(doc).WherePasses(filter).WhereElementIsNotElementType().ToElements()
# Filter Multiple categories, reffering to system families
system_list = [BuiltInCategory.OST_Walls, BuiltInCategory.OST_Ceilings, BuiltInCategory.OST_Floors, BuiltInCategory.OST_Roofs, BuiltInCategory.OST_Walls, BuiltInCategory.OST_RvtLinks]
system_filter_list = List[BuiltInCategory](system_list)
system_filter = ElementMulticategoryFilter(system_filter_list)
system_collector = FilteredElementCollector(doc).WherePasses(system_filter).WhereElementIsNotElementType().ToElements()
# Filter Revit Links
links_collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_RvtLinks).WhereElementIsNotElementType().ToElements()
# Define and open transaction
t = Transaction(doc, "Update Family/Type Name")
t.Start()
# Starting with non system families
for i in category_collector:
# Set duplicate for the TypeName
TypeName = i.Name
TypeNameDuplicate = i.LookupParameter('TypeNameDuplicate')
if TypeNameDuplicate:
TypeNameDuplicate.Set(TypeName)
# Set duplicate for the FamilyName
type_id = i.GetTypeId()
element_type = doc.GetElement(type_id)
family = element_type.Family
name = family.Name
FamilyNameDuplicate = i.LookupParameter('FamilyNameDuplicate')
if FamilyNameDuplicate:
FamilyNameDuplicate.Set(name)
# Duplicates for the system families
for s in system_collector:
SystemTypeName = s.Name
TypeNameDuplicate = s.LookupParameter('TypeNameDuplicate')
TypeNameDuplicate.Set(SystemTypeName)
# Duplicates for linked files
for link in links_collector:
link_filename = link.Name.split(' : ')[0]
LinkFileName = link.LookupParameter('LinkFileName')
if LinkFileName:
LinkFileName.Set(link_filename)
link_name = link.Name.split(' : ')[1]
LinkName = link.LookupParameter('LinkName')
if LinkName:
LinkName.Set(link_name)
link_site = link.Name.split(' : ')[2]
LinkSite = link.LookupParameter('LinkSite')
if LinkSite:
LinkSite.Set(link_site)
# Close transaction
t.Commit()
Replies (0)
