Linked cad elements
Linked cad elements
Linked cad elements
How can I loop the elements in a linked dwg in revit. There should be a way because when I select the dwg and query any element revit does tell its details. Now how do I loop all elements in the linked cad via .net code.
A quick help is needed and highly appreciated.
Thanks & Regards
Anyone Someone out there . At least a reply stating it's possible or it's not possible.
Thanks & regards
arnostlobel
Yes, It is possible 🙂
Ok, here's more about it.... 😉
Look for FilteredElementCollector in the Revit SDK help file. You will need to get the linked document object first (from the host document), and create an element collector with it. Using the collector then you will be able to iterate through elements in the linked file. There shuld be plenty of examples in the SDK about element iteration.
Arnošt Löbel
I didn't got to see any example of iterating elements of a linked cad .
Thanks & Regards
Revitalizer
Dear sanjaymann,
as far as I can see, you cannot browse the elements of an imported or linked DWG file.
Once imported into Revit, such a DWG file appears as an ImportInstance.
Contrary to an imported/linked RVT file which appears as a RevitLinkInstance, an ImportInstance does not provide a method like "GetLinkedDocument()".
Because of this, there is no Document object to browse.
Best regards,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
stav1233
Hey, I was just facing the same situation ,Its been 8 years since this dissociation as ended, is it possible now?
