LIMIT TO TEXT CHARACTERS IN A TEXT BOX (2019)
jledgewood409
jledgewood409
A co-worker of mine has run into a issue where he cannot add anymore characters in his text box. is this something that is known? is there a solution?
jeremytammik
I am not aware of this problem nor a solution.
However, unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
