how to change revit language using api?
developer2F83JZ
developer2F83JZ
Hi All,
I need to change revit language from English to any other.
Is there any function available in API?
Is it possible to change the revit language using revit api?
Please help me to find out the solution.
jeremytammik
No, the Revit API does not support this.
You can use the language switch in the Revit.exe command line, though:
Jeremy Tammik
Developer Technical Services
The Building Coder
