Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Launch Revit.exe with custom parameter
3 REPLIES 3
1533 Views, 3 Replies
Hello everybody,
For a new project I need to create an addin that can have access to the custom parameters given after "Revit.exe" call.
As described here (https://thebuildingcoder.typepad.com/blog/2019/01/face-methods-and-custom-command-line-arguments.htm... I call the exe file in this way : "C:\Program Files\Autodesk\Revit 2021\Revit.exe" "C:\temp\test.rvt" ---- C:\temp\test.txt
My question is : how to get the parameters from code ? (public Autodesk.Revit.UI.Result OnStartup(UIControlledApplication ui_controlled_application))
Thanks a lot
3 REPLIES 3
jeremytammik
You can check whether System.CommandLine works for you in your add-in.
However, I would recommend not even trying, and just using a text file to pass in whatever information your add-in requires. Leave the command line to Revit.exe. It is not yours to interfere with. You can use INI, JSON, XML format, or just human readable text, or whatever you like.
https://thebuildingcoder.typepad.com/blog/2016/09/hololens-escape-path-waypoint-json-exporter.html
> I also implemented two different approaches to store the user-defined add-in option settings, in XML and JSON...
  • Subsidiary external settings command
    • Display modal Windows form
    • Implement form validation using ErrorProvider class, Validating and Validated events
    • Store add-in option settings in XML using the .NET System.Configuration.ApplicationSettingsBase class
    • Store add-in option settings in JSON using custom solution and JavaScriptSerializer class
The entire add-in project is available from the ExportWaypointsJson GitHub repository, and the version discussed here is release 2017.0.0.11.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Thank you Jeremy for your help. I really appreciate.
In fact I don't really need to export / import data. What I need is just to sent some parameters to my Addin at Revit launch.
So to resume the solution :
I call Revit this way :
I obtain the parameters in the code this way :
string[] arguments = Environment.GetCommandLineArgs();
string my_config_file = arguments[3] // Equals "c:\temp\test.txt"
If you don't need to open a file at startup you can also lanch Revit in this way :
"C:\Program Files\Autodesk\Revit 2021\Revit.exe" /C:\temp\test.txt
Forma Design Contest
Rail Community
