IUpdater does not trigger for CableType parameters.
I was trying to create a update for Cable Type (Was introduced in Revit 2026), and I noticed some parameters does not trigger for no reason at all.
Is basically the 3 parameters related to Conductor Material, Temperature Rating, Insulation Material.
Or in BuildInParameter: RBS_WIRE_MATERIAL_PARAM, RBS_WIRE_TEMPERATURE_RATING_PARAM, RBS_WIRE_INSULATION_PARAM.
All 3 parameter is related to a ElementId, and if you get the Element if does not have a Category... probably related.
Even using the Element.GetChangeTypeAny() as the trigger does not work... Nothing trigger when I change the Conductor Material, Temperature Rating, or Insulation Material.
The DocumentChanged event trigger but the update with Element.GetChangeTypeAny() does not.
I know updater is not reliable, some parameters does not trigger, but not triggering with Element.GetChangeTypeAny() is new.
- https://forums.autodesk.com/t5/revit-api-forum/iupdater-does-not-work/m-p/11264539
- https://forums.autodesk.com/t5/revit-api-forum/dynamic-model-updater-get-modified-id-not-returns-all...
@naveen.kumar.t could you pass to the Revit dev team, this happens in 2027 Revit version.
