IUpdater does not trigger for CableType parameters.
ricaun
Advisor Advisor
ricaun
I was trying to create a update for Cable Type (Was introduced in Revit 2026), and I noticed some parameters does not trigger for no reason at all.
Is basically the 3 parameters related to Conductor Material, Temperature Rating, Insulation Material.
Or in BuildInParameter: RBS_WIRE_MATERIAL_PARAM, RBS_WIRE_TEMPERATURE_RATING_PARAM, RBS_WIRE_INSULATION_PARAM.
All 3 parameter is related to a ElementId, and if you get the Element if does not have a Category... probably related.
Even using the Element.GetChangeTypeAny() as the trigger does not work... Nothing trigger when I change the Conductor Material, Temperature Rating, or Insulation Material.
The DocumentChanged event trigger but the update with Element.GetChangeTypeAny() does not.
I know updater is not reliable, some parameters does not trigger, but not triggering with Element.GetChangeTypeAny() is new.
@naveen.kumar.t could you pass to the Revit dev team, this happens in 2027 Revit version.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
naveen.kumar.t
Autodesk Support
Autodesk Support
As part of my investigation, I found that this is a known limitation with the Revit Updater framework, and there is currently no generic solution that addresses all such scenarios.
To highlight the importance of this specific issue, I have submitted it to our engineering team. The issue has been logged as
REVIT-253151
This issue requires further analysis and may require a change to the Revit product. Please keep this reference number for future correspondence.
You are welcome to contact us at any time to request a status update or provide additional information by referencing
REVIT-253151.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Sean_Page
@ricaun, are you using a Class filter or a Category filter on your updater registration? I have found that sometimes it must be one over the other.
Sean Page, AIA, NCARB, LEED AP
Senior Partner, Computational Designer, Architect
ricaun
I'm using category filter like:
new ElementCategoryFilter(BuiltInCategory.OST_Cable)
I tested as well using this application: https://github.com/ricaun-io/RevitAddin.UpdaterTester
