IUpdater does not work?
- Mute
- Permalink
- Report
Hello Devs
I create an application to test when the IUpdater is triggered and what BuiltInParameter was the source of the trigger.
Here is the video about the plugin and the IUpdater problems.
By default, the application adds all the BuiltInParameter on the IUpdater trigger.
Some parameters trigger normally and others do not trigger... Maybe IUpdater does not work with all BuiltInParameter in Revit. Maybe is a feature not a bug.
Another thing I test was in Revit 2023 and I noticed the parameter BuiltInParameter.LEADER_LINE stop triggering.
Now I'm worried to use IUpdater with parameters, my application could break if I use a parameter that decides to stop triggering in Revit 2024 for some reason.
Here is some BuiltInParameter that does not trigger using IUpdater.
BuiltInParameter.ELEMENT_LOCKED_PARAM
BuiltInParameter.TAG_LEADER_TYPE
BuiltInParameter.LEADER_LINE (Revit 2023)This list is what I found but testing manually, I am pretty sure has more BuiltInParameter that does not trigger by IUpdater.
If you what to download and test the application: https://github.com/ricaun-io/RevitAddin.UpdaterTester
Related Posts:
See yaa!
Developer Advocacy and Support +
