Is there any way to place rebar into column or framing part?
hudian
hudian
Hello:
      I am attempt to precast a balcony in Revit 2021,I‘d like to use part to make it,But I'm in trouble. As we know,rebar only can be placed in walls,floors and foundation slabs,and the merged parts can't be offset,as long as I offset any face, and then merge them,it can't place rebar . I'm so depressed about this limit.Is there any way to solve this?
      Let's go back to the balcony,this balcony is comprise with floor and structural framing,I wan't to transform sign element to part,and then merge them, the merged part is my favorite balcony,but it can't place rebar,why?I want place rebar in this part.it can be realize in later release?
Thank you all!
jeremy_tammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
hudian
Thanks for your answer.I am a developer,when I place rebar into a merged part(this part has offset a face),it will throw an error,this part is not a valid host.So I try it in the ui,it still not working.
