PrintManager message
Hi! I get this message every time I try to access the PrintManager in the code.
var manager = document.PrintManager;//Revit throws a message at this line
manager.PrintRange = PrintRange.Select;
manager.PrintSetup.CurrentPrintSetting = manager.PrintSetup.InSession;//Set <In-Session> to avoid this message
 Is there a way to avoid this message like proccessing failures?
Message says: Cant use Adobe Pdf setting with OneNote printer. The settings will be set <in session>
jeremy_tammik
Can you use these settings successfully when driving them manually through the end user interface?
If not, then you obviously cannot do so programmatically either.
Problems are mostly easier to understand and resolve through the end user interface.
RPTHOMAS108
Those information dialogues associated with print manager I believe you can only avoid by using:
DialogBoxShowingEventArgs.OverrideResult or similar
You are effectively driving the same print manager object as is used in the UI and those kind of notifications are part of that logic external to RevitAPI.
It worked for me, thank you!
