Is there any good method for get destination's XYZ?
holyhuman1
Message 1 of 8
holyhuman1
I know my Origin(XYZ), direction(maybe Basis.Z) and  how far from destination(distance). please let me know how to get the destination XYZ in this case.. Is there any good method in Revit API for this?
Thank you 4 reading this.
Replies (7)
Message 2 of 8
jeremy_tammik
Reading your question, I assume you are pretty new to both the Revit API and programming in general.
I would strongly recommend getting some basic grounding in both programming in general and the .NET API specifically before trying to do anything at all in Revit.
Once you have some fundamental grounding, please work through the Revit API getting started material:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#2
It also makes some suggestions on what to learn before getting into the Revit API proper.
The answer to your question is simple:
      XYZ origin = new XYZ( 123, 456, 789 );
      XYZ distance = new XYZ( 1.1, 2.2, 3.3 );
      XYZ destination = origin + distance;
Message 3 of 8
holyhuman1
It is honor to get the answer from you, jeremy! I will try to do your advise, thank you.
but am.. the distance i have is feet( or mm). are there way to change feet to XYZ?  because of below comment.
As you mentioned, Im pretty new in REVIT API. I will try to learn it very hard.  lol
Thank you .
Message 4 of 8
jeremy_tammik
Thank you for your appreciation!
1 foot equals 12 inches.
1 inch equals 25.4 millimetres.
All internal Revit database length measurements are in feet.
Message 5 of 8
holyhuman1
I finally found the solution how to change distance to XYZ. thank you jeremy.
For others, I would to like to write it here. as you know, it is newbie's way. lol
int distance = 10000;
double dis_feet = UnitUtils.ConvertToInternalUnits(distance, DisplayUnitType.DUT_MILLIMETERS);
double vec_x = Convert.ToDouble((MY_DIRECTION).BasisZ.X);
double vec_y = Convert.ToDouble((MY_DIRECTION).BasisZ.Y);
double vec_z = Convert.ToDouble((MY_DIRECTION).BasisZ.Z);
double vecsize = Math.Sqrt((vec_x*vec_x) + (vec_y * vec_y) + (vec_z * vec_z));
double disx = (dis_feet / vecsize) * vec_x;
double disy = (dis_feet / vecsize) * vec_y;
double disz = (dis_feet / vecsize) * vec_z;
XYZ destina_point = new XYZ(Convert.ToDouble((MY_LOCATION).Origin.X) + disx, Convert.ToDouble((MY_LOCATION).Origin.Y) + disy, Convert.ToDouble((MY_LOCATION).Origin.Z) + disz);
Message 6 of 8
jeremy_tammik
Thank you for sharing your current solution.
I would encourage you to explore further how to use point and vector operations to achieve the same thing with much less code, and much more readably, e.g., like this:
      int distance_in_mm = 10000;
      double one_inch = 25.4;
      double one_foot = 12 * one_inch;
      double distance_in_foot = distance_in_mm / one_foot;
      XYZ myDirection = new XYZ( 1, 2, 3 ); // or whatever
      double vecsize2 = myDirection.GetLength();
      XYZ disXyz = (distance_in_foot / vecsize2) * myDirection;
      XYZ myLocation = new XYZ( 5, 6, 7 ); // or whatever
      XYZ destPoint = myLocation + disXyz;
Message 7 of 8
jeremy_tammik
Actually, this would be the standard approach to solve your task:
      double distance_in_feet = distance_in_mm / one_foot;
        + distance_in_feet * myDirection.Normalize();
Message 8 of 8
holyhuman1
it was big help! thank you! lol
