Error "Revit Worker not found"
GSCOTT09
GSCOTT09
Good day.
Please can somebody assistant with Revit 2020 issue.
I keep getting "Revit Worker not found" when attempting to open the program. Or the revit starter screen just loads. I have read all the forums I could get my hands on and nothing has worked.
I have uninstalled everything and reinstall numerous times using all the installation methods.
I have checked my antivirus
I have checked compatibility etc of RevitWorker
I have updated my Windows and used troubleshoot
I also have check "full control access" as stated in a previous blog
Additionally I even attempted to download revit 2021. Of which the download failed at the end stating "error 2147024546"
Please can somebody help.
jeremy_tammik
I am afraid this is not the right place to ask.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to licensing, installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
GSCOTT09
I have posted on every single forum because nobody has helped me.
I pay for this product and can't even use it or get help??
