Is it possible to make a PulldownButton within a PulldownButton ?
dante.van.wettum
dante.van.wettum
In the ribbon i want to add a PulldownButton with several children as pushbuttons.
now i want to add some sub-children to one of those push-buttons so i was thinking of making a PulldownButton within the current PulldownButton.
it seems that the PulldownButton only accepts adding pushbutton ?
is there some way of making this ?
j.buijs
Unfortunately it seems this is not possible.
I tried doing it with the use of AdWindows.dll and I succeeded in adding it, but it just adds a button to it that does nothing. The dropdown list doesn't get added so it's useless.
I created a new PullDownButton next to my original splitbutton with the same items in it.
Then I added a clone of itself and my original splitbutton to it, but both didn't work out.
See attachment. You'll see the 2 new buttons at the bottom, but there is no pulldown list when I click them.
jeremytammik
Dear Dante,
Thank you for your query, and thanks to Jan for his research and answer.
The ADN Xtra Labs 2_Revit_UI_API material covers just about all the user interface functionality that can be achieved using the Revit API:
https://github.com/jeremytammik/AdnRevitApiLabsXtra
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Revitalizer
I've added a suggestion in the Revit Idea Station, citing this thread.
https://forums.autodesk.com/t5/revit-ideas/revit-api-nested-pulldownbuttons/idi-p/8947918
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
