Select elements by ElementID
sakwet
sakwet
I have a list of ElementIDs in the clipboard, how do I select the relevant elements in Revit by using the API? A function similar to 'Select by ID' under inquiry in Manage tab.
I tired using Document.GetElement() method, but could not succeed.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @sakwet ,
There are 2 ways to achieve what you want.
try using the below codes
//USING POSTABLE COMMAND
                RevitCommandId ID = RevitCommandId.LookupPostableCommandId(PostableCommand.SelectById);
                commandData.Application.PostCommand(ID);
//HIGHLIGHTELEMENTS FilteredElementCollector collector = new FilteredElementCollector(doc).OfClass(typeof(Wall)).WhereElementIsNotElementType(); IList<ElementId> list_elementid = collector.ToElementIds() as IList<ElementId>; uidoc.Selection.SetElementIds(list_elementid);
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
john_dalessandro
You can use this function to get the text from the clipboard, then assuming your element ids are comma separated, do something like:
UIDocument.Selection.SetElementIds(
    Clipboard.GetText().Split(',').Select(s => new ElementId(Int32.Parse(s)).ToArray());
We split the text into an array of strings, each of which we parse into an int and make into an ElementId. We make the IEnumerable into a collection by calling .ToArray() and pass that into SetElementIds. You don't even need the elements themselves.
sakwet
@john_dalessandro I got an error
Error CS1061 'ElementId' does not contain a definition for 'ToArray' and no accessible extension method 'ToArray' accepting a first argument of type 'ElementId' could be found
BIM.Frankliang
Dear Friend,
        John lost a ")" , the codes should be :
var uidoc = commandData.Application.ActiveUIDocument;
uidoc.Selection.SetElementIds(Clipboard.GetText().Split(',').Select(s => new ElementId(int.Parse(s))).ToArray());
Best Regards
Frank Liang
TJAD BIM Software Dev Lead
