Is it possible to get Revit application from other external WPF application ?
  • Is it possible to get Revit application from other external .Net / WPF application?
  • My intention is to Process task in Revit from other application.
  • If there is no straight forward solution,Can you suggest me any other work around method.
mikako_harada
Dear Parthiban,
Unfortunately, calling Revit from another application or running Revit out or process is not an officially supported scenario.  You will need to use an add-in running in the Revt to use Revit API.  I hope this explains.
Mikako Harada
Developer Technical Services
