How to create SchedulableField field?
nur91m
nur91m
I want to create multi category schedule with Wall and Room fields. I wrote this -->
 ViewSchedule vs = ViewSchedule.CreateSchedule(doc, new ElementId(BuiltInCategory.INVALID));
after this i need add some schedulable fields of Wall and Room categories? How can I do this? Please help me. Man Wink
thx
Here is how I create schedules, just need to filter for the parameters you want to schedule and within which BuiltInCategory (OST.Walls, etc.)
            using (Transaction t = new Transaction(document, "Create Schedules"))
                t.Start();
                List<ViewSchedule> schedules = new List<ViewSchedule>();
                //Create an empty view schedule of wall category.
                ViewSchedule schedule = ViewSchedule.CreateSchedule(document, new ElementId(BuiltInCategory.OST_Walls), ElementId.InvalidElementId);
                schedule.Name = "SCHEDULE NAME";
                schedules.Add(schedule);
                //Iterate all the schedulable field gotten from the walls view schedule.
                foreach (SchedulableField schedulableField in schedule.Definition.GetSchedulableFields())
                    //Judge if the FieldType is ScheduleFieldType.Instance.
                    if (schedulableField.FieldType == ScheduleFieldType.Instance)
                        //Get ParameterId of SchedulableField.
                        ElementId parameterId = schedulableField.ParameterId;
                        //Add a new schedule field to the view schedule by using the SchedulableField as argument of AddField method of Autodesk.Revit.DB.ScheduleDefinition class.
                        string fieldName = schedulableField.GetName(_doc);
                        if (fieldName == "TEST" || fieldName == "TEST2" || fieldName == "TEST3") //Lots of ORs
                            ScheduleField field = schedule.Definition.AddField(schedulableField);
                            field.HorizontalAlignment = ScheduleHorizontalAlignment.Left;
                            //Group and sort the view schedule by type
                            if (field.ParameterId == new ElementId(BuiltInParameter.ELEM_TYPE_PARAM))
                                ScheduleSortGroupField sortGroupField = new ScheduleSortGroupField(field.FieldId);
                                sortGroupField.ShowHeader = true;
                                schedule.Definition.AddSortGroupField(sortGroupField);
                t.Commit();
                uiDocument.ActiveView = schedule;
