Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Is it possible to call a custom Revit addin externally in a c# program?
2 REPLIES 2
devapi
198 Views, 2 Replies
I have an addin that I created, and it works within REVIT as it is fine. Now I am wondering if there is a way to call created REVIT addins externally via a c# program.
My specific scenario is I'd like to have a c# program or windows application that users would execute on their machines that would gather some form data that would then be passed to my REVIT addin which creates a model based on the data sent to it.
Is there any examples that exist for what I am trying to do?
2 REPLIES 2
jeremy_tammik
in reply to: devapi
Yes, this is possible. Please note that the Revit API requires a valid Revit API context, and such is only provided by Revit within a running session of Revit. exe. Therefore, Revit must be running, snd your custom add-in must be loaded and running as well. With that understood, you can communicate from outside with your add-in and cause it to provide the requested data. The standard way to set up such communication would be the use of an external event. There are lots of sources, ideas, and different approaches to achieve more. Here are some places to start looking:
devapi
in reply to: jeremy_tammik
Thank you, Jeremy.
Rail Community
