Integration between revit and asp.net webapis
khalidfathyuar
khalidfathyuar
i have a web application which provide some services i want to access these services from a wpf in revit when i tried it in wpf app . net framework it works with package system.text.json but when i tried to  do the same in revit through the plugin he told me this error  when i click on get data as get data is calling the service
the output that should came is when i press get data and this outout from the wpf app.net framework
moturi.magati.george
Hi @khalidfathyuar,
A similar issue might have been discussed on this forum before.
Kindly have a look at the same below and see if it helps with your issue.
https://forums.autodesk.com/t5/revit-api-forum/could-not-load-file-or-assembly-system-text-json/td-p...
  Moturi George,     Developer Advocacy and Support,  ADN Open
jeremy_tammik
From your description, it sound as if you do NOT need to access a web service, just read a JSON text file, and you are having trouble using System.Text.Json to do so. No worries, this can be achieved in many other ways:
https://duckduckgo.com/?q=c%23+.net+read+json
khalidfathyuar
Thank you for replying but the solution didn't work with me but i actually solved the problem and the problem was in the system.text  json  nuget package when i worked wit newton json it worked without any problem
khalidfathyuar
Thank you for replying ,the problem was in the system.text  json  nuget package when i worked with newton json  nuget package  it worked without any problem
