Could not load file or assembly 'System.Text.Json
francois.lozes
francois.lozes
Anyone came across an error of this kind (and has an idea on how to fix it):
    Could not load file or assembly 'System.Text.Json, Version=5.0.0.0, Culture=neutral,   PublicKeyToken=cc7b13ffcd2ddd51' or one of its dependencies. The system cannot find the file specified.
It seems like Revit is trying to look for a version of System.Text.Json that is different from the one in the DLL I'm distributing with my adding (v5.0.2).
This kind of error appeared after updating my socketio-client to v3 which has by default System.Text.Json as a dependency instead of Newtonsoft.Json.
jeremy_tammik
Check whether Revit itself is already loading the version you need, or, God forbid, a different one.
You can control which version you load yourself and where from by implementing an appropriate assembly resolver:
https://thebuildingcoder.typepad.com/blog/2014/05/rvtva3c-assembly-resolver.html
More examples of using this technique:
Good luck, and beware of DLL hell. Here are some other discussions on resolving DLL conflicts:
francois.lozes
Thanks a lot Jeremy, just for potential future visitors I solved my issue with:
Assembly OnResolveAssembly(object sender, ResolveEventArgs args)
  string directoryDLLs = Path.GetDirectoryName(Assembly.GetExecutingAssembly().Location);
  // Fix for "Could not load file or assembly 'System.Text.Json" (maybe conflict with Revit)
  if (args.Name.Contains("System.Text.Json"))
    string pathJson = Path.Combine(directoryDLLs, "System.Text.Json.dll");
    return Assembly.LoadFrom(pathJson);
  // other assemblies
  string pathAssembly = Path.Combine(directoryDLLs, args.Name);
  if (File.Exists(pathAssembly))
    return Assembly.LoadFrom(pathAssembly);
  // assembly cannot be resolved
  return null;
public Result OnStartup(UIControlledApplication application)
  // attach load assembly event handler
  AppDomain currentDomain = AppDomain.CurrentDomain;
  currentDomain.AssemblyResolve += OnResolveAssembly;
Mr.CSurvey
I'm having this same issue but I don't know anything about adding code to where its needed. Can you explain how I would go about adding the code?
