Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Inserting Drafting Views From Another File
4 REPLIES 4
mkrausMQRRX
261 Views, 4 Replies
My company has a 'master' Revit project with all of our details in it (All details are drawn in drafting views). I am trying to write a script that copies those details into another project-basically performing an insert views from file function. I have been working on this for awhile but have not been having any luck. For now, I am just trying to load in one drafting view. Below, I have shown my code and the error that dynamo is giving me. Any help would be much obliged!
4 REPLIES 4
mkrausMQRRX
in reply to: mkrausMQRRX
I just figured it out! Here is what I did incase anyone is having the same problem.
mkrausMQRRX
update: this will not copy anything else on the view, just the view itself.
RPTHOMAS108
No use:
ElementTransformUtils.CopyElements(SourceView, ICollection<Of ElementId>, DestView, Transform, CopyPasteOptions)
i.e.
Create empty drafting view in destination document.
Collect elements from drafting view in source document and copy them to newly created destination view.
The overload you used is mainly for model elements i.e.
"This method can be used for copying non-view specific elements only"
mkrausMQRRX
in reply to: RPTHOMAS108
Thank You! That is actually what I ended up doing, I just never got around to posting about it. I also wound up converting the elements on the drafting view into a group and moving that instead of moving each element individually. Not really sure that that is necessary but it gets the job done!
Forma Design Contest
Rail Community
