Independent tag
Independent tag
DWhiteley
Advisor Advisor
Independent tag
DWhiteley
I'm having problems with creating an Independent tag.
var newtag = IndependentTag.Create(doc1, element.Id, view.Id, oRef, false, tagorn, elementXYZ);
And getting this error:
The element is a column. Does a tag have to be loaded in the api first even though one is available in the loaded model. If so, how do I load the tag?
Any help would be much appreciated.
Dave
aignatovich
Hi!
This method requires tag family symbol id as the second parameter, not the id of the element you want to tag:
public static IndependentTag Create(
	Document document,
	ElementId symId, // <- here
	ElementId ownerDBViewId,
	Reference referenceToTag,
	bool addLeader,
	TagOrientation tagOrientation,
	XYZ pnt
If you use this method, you should find tag family symbol first, if it is not presented in the document, you should load it with document.LoadFamily method.
