Exception when extracting data from model
I'm using a custom add-on for Revit for extracting data from my models.
Sometimes Revit crashes during export, I suspect it happens when printing out ViewSheets, but I'm not sure, as the exception occurs irregularly. I don't get any exception in the add-on code, the process simply dies and the Autodesk error dialog box pops up.
The error occurs both in Revit 2016 (Build 16.0.428.0, 20150220_1215(x64)) and Revit 2017.2 (17.0.1150.0, 20171027_0315(x64) 2017.2.3)
I'm attaching a couple of logs. I hope you can see what can be causing the error.
This line from your dmp file seems like a good place to start:
The thread tried to read from or write to a virtual address for which it does not have the appropriate access.
jeremytammik
Maybe your code is trying to read data without being in a valid Revit API context. That used to work, sometimes, a little bit, in earlier versions. In the last few years, it has become almost impossible to make any use of the API without a valid context, and that might cause the kind of behaviour you describe.
Jeremy Tammik
Developer Technical Services
The Building Coder
