I would like to launch a Command After the Export File Form Closes
MiguelVJC82W
MiguelVJC82W
I have a custom button that launches the DXF Export window. I would like to be able to Launch another method after the Export window is closed. Currently my code opens the Export Form and then launches my other method, but I need the second method to process using information from the form. Is there a way to do this that I am just not seeing?
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using System;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.UI.Events;
using System.Windows.Forms;
using System.Xml.Linq;
namespace Ribbon
      [Transaction(TransactionMode.Manual)]
      [Regeneration(RegenerationOption.Manual)]
      class CmdComboGroup : IExternalCommand
          public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
             CmdDFX2PDF n = new CmdDFX2PDF();
             n.Execute(commandData, ref message, elements);
             CmdCAD r = new CmdCAD();
             r.Execute(commandData, ref message, elements);
             return Result.Succeeded;
jeremy_tammik
The standard Revit API approach to launch a command after the previous one has been completed is to use the Idling event:
However, there are other possibilities as well. For example, check out these recent discussions on similar topics:
