Lighting Fixtures in opposite direction
MiguelGT17
MiguelGT17
Greetings to everyone,
I wish to place lighting fixtures at the top of mirrors. So far, I've achieved to placed them in the opposite direction
Manually workflow
C# macro:
XYZ mirrorLoc = new XYZ(centroidMirror.X,centroidMirror.Y,bb.Max.Z)
FamilyInstance famIns = doc.Create.NewFamilyInstance(mirrorLoc,vanityLight, wallMirror, firstLevel,StructuralType.NonStructural);
What would it be the best approach for this matter, look into the rotation parameters, mirror, etc. Which one do you suggest?
All the best,
Miguel G.
jeremy_tammik
Rotate them into the correct position and orientation manually in the user interface.
Compare their element properties and relationships before and afterwards using RevitLookup and other database exploration tools:
https://thebuildingcoder.typepad.com/blog/2017/01/virtues-of-reproduction-research-mep-settings-onto...
That can give you a hint of what properties to modify to achieve the desired orientation programmatically.
sragan
Also, are they just rotated wrong, or are they actually on the wrong side of the wall?
MiguelGT17
I see the hand orientation and facing orientation having a negative value although those are only read parameters and when using fliphand(),flipOrientation(), rotate() it retrieves a false bool operation.
MiguelGT17
Regarding the first point, I'm using rotate() command but it can not be rotated neither the fliphand() or fliporientation() works
For the second scenario, how is it that I can set the right side of the wall?
