I would like to launch a Command After the Export File Form Closes
I have a custom button that launches the DXF Export window. I would like to be able to Launch another method after the Export window is closed. Currently my code opens the Export Form and then launches my other method, but I need the second method to process using information from the form. Is there a way to do this that I am just not seeing?
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using System;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.UI.Events;
using System.Windows.Forms;
using System.Xml.Linq;
namespace Ribbon
[Transaction(TransactionMode.Manual)]
[Regeneration(RegenerationOption.Manual)]
class CmdComboGroup : IExternalCommand
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
CmdDFX2PDF n = new CmdDFX2PDF();
n.Execute(commandData, ref message, elements);
CmdCAD r = new CmdCAD();
r.Execute(commandData, ref message, elements);
return Result.Succeeded;
