Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
I cannot get RevitLinkType WorksetConfiguration.Close to work
3 REPLIES 3
Rockit_for_Revit
611 Views, 3 Replies
I have collected the Link WorksetIds I want to close and put this into the following code.
objWorksetConfiguration.Close(ListOfWorksetID)
objRevitLinkType.LoadFrom(objModelPath, objWorksetConfiguration)
The Link is the same, when I run the command the link is reloaded however the Link worksets are not closed.
Any ideas?
Kind Regards
David
3 REPLIES 3
Open worksets is working successfully.
objWorksetConfiguration.Open(lstOfWorksetIDsToOpen)
However still cannot get .close to work.
Kind Regards
David
zhong_wu
in reply to: Rockit_for_Revit
Hi David, Interesting, I tried with one of our sample revit file(added some worksets), and open the file by the code as follow, the WorksetConfiguration.Close() method works as good as I expected. I can't reproduce the issue as you mentioned so far, maybe you can share with me the reproduce sample code and the revit files, I would be happy to check more.
public Autodesk.Revit.UI.Result Execute(ExternalCommandData commandData,
    ref string message, Autodesk.Revit.DB.ElementSet elements)
    // Get the application and document from external command data.
    UIApplication app = commandData.Application;
    // the list of worksets that will be closed
    List<WorksetId> wsIds = new List<WorksetId>();
    wsIds.Add(new WorksetId(0));
    wsIds.Add(new WorksetId(163));
    wsIds.Add(new WorksetId(343));
    wsIds.Add(new WorksetId(344));
    WorksetConfiguration wsConf = new WorksetConfiguration(WorksetConfigurationOption.OpenAllWorksets);
    wsConf.Close(wsIds);
    // open the file from BIM360 Docs
    ModelPath modelPath = ModelPathUtils.ConvertCloudGUIDsToCloudPath(new Guid("55a82cfc-680d-XXXX-bcf7-2f11837062a5"), new Guid("0e57bf28-XXXX-443c-9d10-aee9ef0d37f4"));
    OpenOptions oo = new OpenOptions();
    oo.SetOpenWorksetsConfiguration(wsConf);
        app.OpenAndActivateDocument(modelPath, oo, false);
    return Autodesk.Revit.UI.Result.Succeeded;
John Wu
Developer Technical Services
Autodesk Developer Network
Rockit_for_Revit
in reply to: zhong_wu
Thank you,
If you want to modify the Worksets you must begin with WorksetConfigurationOption.CloseAllWorksets or WorksetConfigurationOption.OpenAllWorksets. This was where I was going wrong.
WorksetConfiguration = New WorksetConfiguration(WorksetConfigurationOption.CloseAllWorksets)
Kind Regards
David
Forma Design Contest
Rail Community
