I can not load the Framework .NET 4.7 in Visual Studio.
My Visual Studio have the 4.71 framework .NET. When I try to build the solution I get an error. I should work in the same way using 4.71 .NET  instead of using 4.70 .NET?
jeremytammik
I ran into the same problem, I think, when I started working with Revit 2020:
I installed the developer pack and support tools for the .NET framework 4.7.2.
I was unable to compile.
The problem was resolved when I installed the developer pack and support tools for the .NET framework 4.7 with no suffix, i.e., 4.7.0:
https://thebuildingcoder.typepad.com/blog/2019/04/the-revit-2020-fcs-api-and-sdk.html#6
I hope that will help in your case as well.
Jeremy Tammik
Developer Technical Services
The Building Coder
Jerremy thanks a lot for your help
