Solid as OpenShell DirectShape
vanlion
Message 1 of 12
vanlion
With a code i create in C# i can make a Solid DirectShape. But i'm also looking how you can make an OpenShell DirectShape. So you get a DirectShape like dynamo does. Anybody can point me in a direction what to do?
Thanks.
My C# DirectShape:
Dynamo DirectShape:
Replies (11)
Message 2 of 12
jeremytammik
You can define the geometry for your direct shape element using the ShapeBuilder class:
http://www.revitapidocs.com/2019/66c1678c-2e01-e0de-1386-5a0e1eb3ccff.htm
That class enables you to build wireframe, open b-rep face or solid geometry, just as you please.
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 12
vanlion
Thanks jeremy!
So it was easy to create a wireframe with this class. but when i try to do this for creating faces, it's a little bit harder to understand which step you have to take. Do you need to use BRepBuilder or TessellatedShapeBuilder? i thought let's try a simple face creation to a directShape geometry. So i use the bottom lines from my created solid. I tried this with BRepBuilder but i was getting the error not enough faces.
Message 4 of 12
jeremytammik
Glad to hear that helped. I think the BRepBuilder is possible to use, but not encouraged. The TesselatedShapeBuilder ought to be easier to use than the BRepBuilder.
Also note that it’s much easier to use GeometryCreationUtilities functions to create extrusions:
https://thebuildingcoder.typepad.com/blog/2018/02/directshape-from-brepbuilder-and-boolean.html
Jeremy Tammik
The Building Coder
Message 5 of 12
vanlion
Yes the bRep looks very complex to create a shape. The shape i made as you can see at the beginning is creates as follows:
List<CurveLoop> profile3 = new List<CurveLoop>();
    profile3.Add(CreateCurveloop(pointList1);
    profile3.Add(CreateCurveloop(pointList2);
    Solid loft = GeometryCreationUtilities.CreateLoftGeometry(profile3 ,options);
But there isn't a simple step to say this solid must openshell or isn't solid but had only faces like in dynamo.
Maybe i'm missing something simple but i really want to understand the differeneces 🙂
Message 6 of 12
jeremytammik
Message 7 of 12
vanlion
Thanks again for sending the examples.
I will take a look at it and let you know what i can figure out!
Message 8 of 12
vanlion
Hi @jeremytammik
I took me some time but i got it almost working like it should, with the code underneath. This makes Triangled faces from the solid faces. The last option i'm looking for is creating these faces only that they are not triangled. I can't find how to do this with bRep Builder as you said. I hope it's as easy as making triangled faces like this code.
Thanks!
        public TessellatedShapeBuilderResult Build_Tessellate(Face faces)
            Mesh mesh = faces.Triangulate();
            TessellatedShapeBuilder builder = new TessellatedShapeBuilder();
            builder.OpenConnectedFaceSet(false);
            List<XYZ> args = new List<XYZ>(3);
            XYZ[] triangleCorners = new XYZ[3];
            for (int i = 0; i < mesh.NumTriangles; ++i)
                MeshTriangle triangle = mesh.get_Triangle(i);
                triangleCorners[0] = triangle.get_Vertex(0);
                triangleCorners[1] = triangle.get_Vertex(1);
                triangleCorners[2] = triangle.get_Vertex(2);
                TessellatedFace tesseFace = new TessellatedFace(triangleCorners, ElementId.InvalidElementId);
                if (builder.DoesFaceHaveEnoughLoopsAndVertices(tesseFace))
                    builder.AddFace(tesseFace);
            builder.CloseConnectedFaceSet();
            builder.Target = TessellatedShapeBuilderTarget.AnyGeometry;
            builder.Fallback = TessellatedShapeBuilderFallback.Mesh;
            builder.Build();
            TessellatedShapeBuilderResult result2 = builder.GetBuildResult();
            return result2;
Woktin part with TessellatedBuilder:
Message 9 of 12
jeremytammik
Congratulations on the good progress!
I am sorry to say that I think it may not be possible to hide individual edges of the triangulated faces.
I hope someone corrects me on this if I am wrong, and points out how it can be achieved.
Thank you!
Jeremy Tammik
The Building Coder
Message 10 of 12
vanlion
Thanks Jeremy. Yes i feel i'm almost there. The progress i've made is creating Tessellated faces (see earlier posts)
With the same ShapeBuilder i now can build non triangled faces, only if they are planar (see image1, simple box) and they are individually selectable, what i need!
When using this with an object that doesn't have all planar faces you see it not creates all the single faces (image2)
The result i need is the same as image3 but this is a solid shape and i need individually faces. So the conclusion for now is that Tessellated builder can't build my non planar shape in individually faces that aren't triangled. Anyone an idea what the right builder?
Annotation 2019-06-13 095239.pngAnnotation 2019-06-13 095338.pngAnnotation 2019-06-13 095440.png
List<Solid> sol = new List<Solid>();
Solid loft = GeometryCreationUtilities.CreateLoftGeometry(profileLoop, options);
sol.Add(loft); foreach (Solid s in sol) { foreach (Face f in s.Faces) { Build_Tessellate2(f); ElementId categoryId = new ElementId(BuiltInCategory.OST_GenericModel); DirectShape ds = DirectShape.CreateElement(doc, categoryId); ds.ApplicationId = System.Reflection.Assembly.GetExecutingAssembly().GetType().GUID.ToString(); ds.ApplicationDataId = Guid.NewGuid().ToString(); foreach (TessellatedShapeBuilderResult t1 in Build_Tessellate2(f)) { ds.SetShape(t1.GetGeometricalObjects()); ds.Name = "Single_Surface"; } } }
public List<TessellatedShapeBuilderResult> Build_Tessellate2(Face faces) { Mesh mesh = faces.Triangulate(); List<XYZ> vert = new List<XYZ>(); foreach (XYZ ij in mesh.Vertices) { XYZ vertices = ij; vert.Add(vertices); } TessellatedShapeBuilder builder = new TessellatedShapeBuilder(); builder.OpenConnectedFaceSet(false); //Filter for Title Blocks in active document FilteredElementCollector materials = new FilteredElementCollector(m_revit.Application.ActiveUIDocument.Document) .OfClass(typeof(Autodesk.Revit.DB.Material)) .OfCategory(BuiltInCategory.OST_Materials); ElementId materialId = materials.First().Id; builder.AddFace(new TessellatedFace(vert, materialId)); builder.CloseConnectedFaceSet(); builder.Target = TessellatedShapeBuilderTarget.AnyGeometry; builder.Fallback = TessellatedShapeBuilderFallback.Mesh; builder.Build(); TessellatedShapeBuilderResult result3 = builder.GetBuildResult(); List<TessellatedShapeBuilderResult> res = new List<TessellatedShapeBuilderResult>(); if (result3.Outcome.ToString() == "Sheet") { res.Add(result3); } return res; }
Message 11 of 12
jeremytammik
You say, '... an object that doesn't have all planar faces ... (image2)'.
However, as far as I can tell, all the faces in image2 are planar after all.
Why do you say they are non-planar?
Jeremy Tammik
The Building Coder
Message 12 of 12
vanlion
It's hardly to see in the image.
Attached you can find the RVT model as a solid
