How to uncheck "Constrain"
nitinjambhale
nitinjambhale
Hi Guys,
I am trying to simulate the Copy + Move command from the API.
Manual Steps: I am selecting 2 elements and pressing the "CO" command, then I need to uncheck the "Constrain" checkbox, and then I am selecting the different location to paste it.
The question is, how I can uncheck "Constrain" programmatically?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @nitinjambhale ,
How are you executing copy and move commands?
Are you using postable command or ElementTransformUtils?
As per my understanding, if you are using the postable command, you can check/uncheck the constrain option.
If you are using ElementTransformUtils.CopyElement/ElementTransformUtils.MoveElement you will provide a point as one of the parameters so here no need to check/uncheck the constrain option. The element will be moved to/copied to a  point(XYZ).
I hope this helps.
If this doesn't help, Could you please explain why you need to uncheck the constrain option?
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
nitinjambhale
I am using ElementTransformUtils.CopyElements...
If I do not deselect "Constrain" or press shift, I only allowed to paste that vertically, but if I press shift and then move my cursor, I can allow anywhere to paste that fitting.
Can you please give me an example, how can I achieve this with PostableCommands?
nitinjambhale
Hi Naveen,
It's done! Actually, I used another overload of CopyElements that takes transform...
