Create/Save project with UNC Paths
No aplicable
1.058 Vistas
6 Respuestas
Mensaje 1 de 7
No aplicable
I have a script for creating new models - created with Python in Dynamo. Using UNC paths (\\local\folder\folder\...) instead of traditional (drive:\folder\folder\...) paths I get the following error:
Exception: The model could not be saved: (COleException 0x80030002)
Unfortunately, I don't have the option to not use a UNC path. I'm certain the problem originates when I use the result from "ConvertUserVisiblePathToModelPath" in SaveAs(..)
path = DB.ModelPathUtils.ConvertUserVisiblePathToModelPath(unc_path_here)
doc.SaveAs(path, sopt)
I have also tried the FilePath method, here the script never stops..
https://www.revitapidocs.com/2015/0776a818-f032-a332-ac59-962953d8493a.htm
https://www.revitapidocs.com/2015/db245ec6-e07a-b989-077a-a2947e308345.htm
Does anyone have a suggestion how to fix the problem? 🙂
0 Me gusta
1.059 Vistas
6 Respuestas
  • unc
Respuestas (6)
Mensaje 2 de 7
jeremytammik
Can you use SUBST?
https://en.wikipedia.org/wiki/SUBST
Jeremy Tammik
Developer Technical Services
The Building Coder
0 Me gusta
Mensaje 3 de 7
No aplicable
Hi Jeremy,
I can use SUBST, wouldn't it give issues for other users?  or if I link models? using SUBST...
(EDIT: wrong account :-S)
0 Me gusta
Mensaje 4 de 7
jeremytammik
Yes, of course, that might require some tricky coordination...
Sorry for being such an egoist and individualist, I always forget about the teamwork stuff...
Jeremy Tammik
The Building Coder
0 Me gusta
Mensaje 5 de 7
No aplicable
hehe 🙂
Besides SUBST, it's not possible to work with UNC paths in Revit?
If not, do you know if Autodesk is planning to support UNC paths from the Revit API?
0 Me gusta
Mensaje 6 de 7
No aplicable
Nope, SUBST is not an option... 😞
0 Me gusta
Mensaje 7 de 7
No aplicable
update...
DB.FilePath works with UNC paths ....
if you just aren't stupid enough to make a minor mistake in the path...
0 Me gusta
