Create/Save project with UNC Paths
I have a script for creating new models - created with Python in Dynamo. Using UNC paths (\\local\folder\folder\...) instead of traditional (drive:\folder\folder\...) paths I get the following error:
Exception: The model could not be saved: (COleException 0x80030002)
Unfortunately, I don't have the option to not use a UNC path. I'm certain the problem originates when I use the result from "ConvertUserVisiblePathToModelPath" in SaveAs(..)
path = DB.ModelPathUtils.ConvertUserVisiblePathToModelPath(unc_path_here)
doc.SaveAs(path, sopt)
I have also tried the FilePath method, here the script never stops..
https://www.revitapidocs.com/2015/0776a818-f032-a332-ac59-962953d8493a.htm
https://www.revitapidocs.com/2015/db245ec6-e07a-b989-077a-a2947e308345.htm
Does anyone have a suggestion how to fix the problem? 🙂
  • unc
jeremytammik
Can you use SUBST?
https://en.wikipedia.org/wiki/SUBST
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Hi Jeremy,
I can use SUBST, wouldn't it give issues for other users?  or if I link models? using SUBST...
(EDIT: wrong account :-S)
jeremytammik
Yes, of course, that might require some tricky coordination...
Sorry for being such an egoist and individualist, I always forget about the teamwork stuff...
Jeremy Tammik
The Building Coder
hehe 🙂
Besides SUBST, it's not possible to work with UNC paths in Revit?
If not, do you know if Autodesk is planning to support UNC paths from the Revit API?
Nope, SUBST is not an option... 😞
update...
DB.FilePath works with UNC paths ....
if you just aren't stupid enough to make a minor mistake in the path...
