Cropview shapes not matching in plan during export to DWG
CaoduroC
CaoduroC
Good morning,
in an attempt to overcome the limitation in Revit to export view in sheet in world coordinates, we have explored the idea to export the view in the sheets separately and then relink them within AutoCAD.
The biggest issue we are facing at the moment is that the cropshapes are not matching the coordinates and the location in plan.
When we split the view in multiple crop regions we end up to have multiple crop views, each of them provides a curve loop and with that the 4 corners of the crop itself.
2020-10-09 14_20_40-Autodesk Revit 2020.2 - [M80NS-300-415-MOD-AEC-410-000-3D-RAMP_J.rvt - Structura.jpg
This info is available within the API using the  ViewGetCropRegionShapeManager. I thought that this will somehow match in dimension and location the position in plan when the view is not cropped so we can recreate a layout in AutoCAD and match these dimensions, but that is not the case.
2020-10-09 14_31_03-Autodesk AutoCAD 2021 - [1020 - FOUNDATION LAYOUT 300aaa.dwg].jpg
Now this is a problem, because there is no way we can find a relatoin between the shapes (and TBH the point don't make sent as well).
@jeremytammik do you have any idea or solution to this problem? Anyone else in the forum that has solved this issue before? Are these information even accessible through the APIs?
The Enhanced DWG Export is not a solution either, if someone thinks to provide that as suggestion.
Here the code in Python/Dynamo just to test the functionality
dwgExportOptions = DWGExportOptions.GetPredefinedOptions(doc, dwgExportName);
viewsToExport = []
loops = []
shapes = []
for sheet in sheets:
	s = {}
	data = []
	viewports = sheet.GetAllViewports()
	for viewport in viewports:
		d = {}
		v = doc.GetElement(viewport)
		exportWC = v.LookupParameter(paramName).AsInteger()
		if (exportWC == 1):
			view = doc.GetElement(v.ViewId)
			viewsToExport.Add(view.Id)
			viewName = view.Name
			viewOrigin = XYZToPoint(view.Origin, du)
			viewScale = view.Scale
			viewCropBoxMin = XYZToPoint(view.CropBox.Min, du)
			viewCropBoxMax = XYZToPoint(view.CropBox.Max, du)
			viewCropBoxMin[0] = viewCropBoxMin[0] + east
			viewCropBoxMin[1] = viewCropBoxMin[1] + north
			viewCropBoxMax[0] = viewCropBoxMax[0] + east
			viewCropBoxMax[1] = viewCropBoxMax[1] + north
			viewCropBoxLoops = view.GetCropRegionShapeManager().GetCropShape()
			viewAnnotationCropBoxLoops = view.GetCropRegionShapeManager().GetAnnotationCropShape()
			splitRegions = view.GetCropRegionShapeManager().NumberOfSplitRegions
			shapes = []
			loop = []
			viewCropBoxOrigin = []
			for curveLoop in viewCropBoxLoops:
				shape = []
				for curve in curveLoop:
					curveOrigin = XYZToPoint(curve.Origin, du)
					loop.Add([curveOrigin[0], curveOrigin[1]])
					#shapes.Add([curveOrigin[0], curveOrigin[1]])
					shape.Add([curveOrigin[0]+east, curveOrigin[1]+north])
				p1X = shape[0][0]
				p1Y = shape[0][1]
				p2X = shape[2][0]
				p2Y = shape[2][1]
				loops.Add(loop)
				viewCropBoxOrigin.Add([(p1X + p2X)/2 , (p1Y + p2Y)/2])
				shapes.Add(shape)
			rX = view.CropBox.Transform.BasisY.X
			rY = view.CropBox.Transform.BasisY.Y
			viewCropboxRotation = math.degrees(math.atan2(rX, rY))
			viewportBoxCenter = XYZToPoint(v.GetBoxCenter(), duMM)
			viewportBoxOutlineMinimumPoint = XYZToPoint(v.GetBoxOutline().MinimumPoint, duMM)
			viewportBoxOutlineMaximumPoint = XYZToPoint(v.GetBoxOutline().MaximumPoint, duMM)
			d["viewUnit"] = du.ToString()
			d["viewName"] = viewName
			d["viewOrigin"] = viewOrigin
			d["viewRotationUp"] = math.degrees(math.atan2(view.UpDirection.Y, view.UpDirection.X))
			d["viewScale"] = viewScale
			d["viewBoundingBox"] = [viewCropBoxMin, viewCropBoxMax]
			d["viewportBoxCenter"] = viewportBoxCenter
			d["viewportBoxOutlineMinimumPoint"] = viewportBoxOutlineMinimumPoint
			d["viewportBoxOutlineMaximumPoint"] = viewportBoxOutlineMaximumPoint
			d["viewCropbox"] = shapes
			d["viewCropboxTopAnnotationOffset"] = UnitUtils.ConvertFromInternalUnits(view.GetCropRegionShapeManager().TopAnnotationCropOffset, du)
			d["viewCropboxBottomAnnotationOffset"] = UnitUtils.ConvertFromInternalUnits(view.GetCropRegionShapeManager().BottomAnnotationCropOffset, du)
			d["viewCropboxLeftAnnotationOffset"] = UnitUtils.ConvertFromInternalUnits(view.GetCropRegionShapeManager().LeftAnnotationCropOffset, du)
			d["viewCropboxRightAnnotationOffset"] = UnitUtils.ConvertFromInternalUnits(view.GetCropRegionShapeManager().RightAnnotationCropOffset, du)
			d["viewCropboxOrigin"] = viewCropBoxOrigin
			d["viewCropboxRotation"] = viewCropboxRotation
			d["splitRegionsNumber"] = splitRegions
			if splitRegions > 1:
				TransactionManager.Instance.EnsureInTransaction(doc)
				tempView = view.Duplicate(ViewDuplicateOption.WithDetailing)
				csm = doc.GetElement(tempView).GetCropRegionShapeManager()
				csm.RemoveSplit()
				TransactionManager.Instance.TransactionTaskDone()
				export = doc.Export(dirPath, viewName, List[ElementId]([tempView]), dwgExportOptions)
			else:
				export = doc.Export(dirPath, viewName, List[ElementId]([view.Id]), dwgExportOptions)
			data.Add(d)
		else:
			continue
	s["sheetName"] = sheet.Name
	s["viewUnit"] = du.ToString()
	s["sheetNumber"] = sheet.SheetNumber
	s["data"] = data
	export = doc.Export(dirPath, sheet.Name, List[ElementId]([sheet.Id]), dwgExportOptions)
	output.Add(s)
#Declaration section#
import sys
import clr
import math
clr.AddReference('System')
from System.Collections.Generic import List
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
import os
clr.AddReference('ProtoGeometry')
from Autodesk.DesignScript.Geometry import *
clr.AddReference('RevitAPIUI')
from  Autodesk.Revit.UI import *
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import *
from Autodesk.Revit.Creation import *
clr.AddReference('RevitNodes')
import Revit
clr.ImportExtensions(Revit.Elements)
clr.ImportExtensions(Revit.GeometryConversion)
clr.AddReference('RevitServices')
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
#Convert a Revit internal point
def XYZToPoint(pt, du):
    x = UnitUtils.ConvertFromInternalUnits(pt.X, du)
    y = UnitUtils.ConvertFromInternalUnits(pt.Y, du)
    #z = UnitUtils.ConvertFromInternalUnits(pt.Z, du)
    return [x, y]
#Access the active document#
doc = DocumentManager.Instance.CurrentDBDocument
uidoc = DocumentManager.Instance.CurrentUIApplication.ActiveUIDocument
#Get the length display unit for the active project
du = doc.GetUnits().GetFormatOptions(UnitType.UT_Length).DisplayUnits
duMM = DisplayUnitType.DUT_MILLIMETERS
pbp = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_ProjectBasePoint).WhereElementIsNotElementType().FirstElementId()
east = UnitUtils.ConvertFromInternalUnits(doc.GetElement(pbp).get_Parameter(BuiltInParameter.BASEPOINT_EASTWEST_PARAM).AsDouble(), du)
north = UnitUtils.ConvertFromInternalUnits(doc.GetElement(pbp).get_Parameter(BuiltInParameter.BASEPOINT_NORTHSOUTH_PARAM).AsDouble(), du)
#Start a transaction on the active document#
#TransactionManager.Instance.EnsureInTransaction(doc)
#Insert here your code#
dirPath = IN[0]
paramName = IN[1]
dwgExportName = IN[2]
sheets = UnwrapElement(IN[3])
output = []
viewsToExport = []
loops = []
shapes = []
    s = {}
    data = []
        d = {}
        if (exportWC == 1😞
            shapes = []
            loop = []
                shape = []
                p1X = shape[0][0]
                p1Y = shape[0][1]
                p2X = shape[2][0]
                p2Y = shape[2][1]
                loops.Add(loop)
                shapes.Add(shape)
                csm.RemoveSplit()
            else:
            data.Add(d)
        else:
            continue
    s["data"] = data
    output.Add(s)
#Dispose the active transaction
#TransactionManager.Instance.TransactionTaskDone()
#List outputs#
OUT = output, loops
Thanks!
CaoduroC
Apologies for the double code, I went out of time and couldn't remove it...
