How to set the z Justification of Structural Framing:Beam
1073092683
1073092683
How to set the z Justification of Structural Framing:Beam through the API
jeremy_tammik
Well, as you can see yourself from your screen snapshot, the options seem to be limited to a rather short list. Sometimes, such list entries are represented as integer numbers or enumeration values. Please look at your BIM yourself using RevitLookup or other Revit database snooping tools and determine what values can be used. Here are some recommendations on How to research to find a Revit API solution:
https://thebuildingcoder.typepad.com/blog/2017/01/virtues-of-reproduction-research-mep-settings-onto...
