TessellatedFace
TessellatedFace
pmeigneux
Message 1 of 9
TessellatedFace
pmeigneux
for TessellatedFace(IList<IList<XYZ>> allLoopVertices, ElementId materialId) :
If I understood correctly the first parameter is a list of list of points.
The first list contains a list of triangles (3 points) which define the surface.
On the other hand, for the following lists I do not understand what must provide
because the first list provides only the "solid" surface without the holes.
Philippe.
Replies (8)
Message 2 of 9
jeremy_tammik
The TessellatedFace constructor has two overloads:
https://www.revitapidocs.com/2023/915c466c-4dfa-15e6-6267-72fea11af27d.htm
Taking just a single list of points, it constructs a tessellated face without holes.
With a list of lists of points, you can construct a tessellated face that has holes.
The lists contain boundary vertices without duplication of the ends. The first array describes the outer loop, the following arrays, if any, inner loops. It is expected that vertices of outer boundary are listed in CCW order with respect to the face normal in the solid, and the vertices of inner loops in CW order.
There is no requirement for triangulation or any such thing.
I would recommend that you ensure that each individual list describes a simple polygon, i.e., a polygon that does not intersect itself and has no holes:
https://en.wikipedia.org/wiki/Simple_polygon
Message 3 of 9
pmeigneux
hello Jeremy,
If a tessellated surface contains a hole but the tesselated does not cover that hole. Is it possible to go through the method without a hole?
I don't have the tessellation of this hole.
Philippe.
Message 4 of 9
jeremy_tammik
I do not understand what you mean by "a tessellated surface contains a hole but the tessellated does not cover that hole". Is that not a contradiction in itself?
Message 5 of 9
pmeigneux
hello,
example :
!   tessallated                          !
!        !  nothing       !               !
Philippe.
Message 6 of 9
jeremy_tammik
If you want the hole in your result, pass in the outer four point CCW in the first list, and the inner four points CW in the second.
If you do not want the hole in your result, skip the inner four points. In that case, you can use either one of the two constructors.
I do not understand what you problem is with that.
Message 7 of 9
pmeigneux
hi,
I receive a file which contains solids defined for each of its faces by a set of vertices of triangles and a set of edges. I don't have any more information.
Philippe.
Message 8 of 9
pmeigneux
Hi Jeremy,
for the tessellation should we only pass all the vertices of triangles or groups of 3 vertices?
example for a square defined for 2 triangles, I have to pass 4 points or 2x3 points.
Philippe.
Message 9 of 9
jeremy_tammik
Please read my initial answer above more carefully, or simply read the API documentation that I pointed out. I very clearly stated: There is no requirement for triangulation or any such thing. Just pass in an ordered list of vertices for a simple polygon.
I'll repeat this once again, just in case it helps:
