Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to scale a solid?
2 REPLIES 2
2189 Views, 2 Replies
Hello everyone,
I want to scale a solid with origin as its center, but I can't find any way to do it.
I try this: (have a Solid named solid)
Transform transform = Transform.CreateTranslation(new XYZ(0, 0, 0)).ScaleBasis(1.1);
Solid sclSolid = SolidUtils.CreateTransformed(solid, transform);
But it's scaled from the basis (0,0,0).
Please help, thank you!
2 REPLIES 2
jeremytammik
You can achieve what you need by concatenating several transforms, e.g., to translate the solid from the origin to its centre, then to scale, then to translate it back again.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
in reply to: jeremytammik
Thank you Jeremy,
I think it might be the only way :).
Autodesk Customer Advisory Groups
Rail Community
