Retrieve DividedPath points
1368026189
1368026189
Hello all,
I am trying to access the DividedPath's points using the Revit API with no luck.
Options opts = divPath.Document.Application.Create.NewGeometryOptions();
opts.ComputeReferences = true;
opts.View = divPath.Document.ActiveView;
GeometryElement geoele = divPath.get_Geometry(opts);
but  geoele return nothing back
How can this be done using the API?  I can get the info from revitLookup so there must be some way
Thank you very much in advance.
jeremytammik
Congratulations on determining that you can access the required information using RevitLookup.
There is your answer, right there.
RevitLookup is based entirely on the Revit API:
https://github.com/jeremytammik/RevitLookup
Simply debug it to see how the information you seek is accessed.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Hi Jeremy
I tried but it does not work, in the Snoop Objects Window, The Field and Value DataList has no Value while debug it
Thanks Jeremy
I figured that I need a doc.Regenerate() before my operation
