How to retrieve column cross section angle to BasisX or BasisY
I'm trying to place a family instance that line up with the rotated columns.
but how can I retrieve column cross section angle to the BasisX? and I don't want to change the column to slanted
any suggestions? Thanks
jeremytammik
As far as I know, the column always has a valid location.
Possibly, it is a location point for a vertical column and a location line when not vertical.
In either case, you can easily calculate the angle from that data: 90 degrees for a point location, and using the location line start and end points in the other case.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Thanks for your tips.
I eventually figure this out by using the Revit Lookup.
LocationPointloPoint = fi.Location as LocationPoint;
double poRota = loPoint.Rotation;
This returns exactly what i need.
