column creation
column creation
Message 1 of 12
column creation
hi everyone,i get a problem here: I used Revit API (document.Create.NewFamilyInstance() )to create columns ,and all the column instances were ostensibly created correctly; but when i manipulated one of them(such as copy and move),Revit shows the message like follows:
Replies (11)
Message 2 of 12
Aaron.Lu
Dear, not sure why this happens, would you like to provide a small code sample and .rvt file so that I can reproduce your problem?
thanks.
Aaron Lu
Developer Technical Services
Autodesk Developer Network
Message 3 of 12
Message 4 of 12
please open thie .rvt file , use the familysymbol "KL1(1)-300*600mm" to create a instance, then hopely you can see the phenomenon.
Message 5 of 12
Aaron.Lu
is the attachment missing?
Aaron Lu
Message 6 of 12
soory my mistake
Message 7 of 12
i can't sent the rvt file to you through attachment file, it dose not work! is there any other way i can sent you this file?
Message 8 of 12
Aaron.Lu
I guess it does not support uploading rvt directly, would you try to upload a zip file containing rvt?
Aaron Lu
Message 9 of 12
Aaron.Lu
Also, would you paste some code snippet as well? because there are too many NewFamilyInstance overloads, i'm not sure which one you are using.
Aaron Lu
Message 10 of 12
thank you for your reminding.
Message 11 of 12
Message 12 of 12
Aaron.Lu
If it still does not work, I would suggest using skydrive, dropbox or other cloud sharing tools.
Aaron Lu
