Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to remove my external command from External tools list?
3 REPLIES 3
nur91m
776 Views, 3 Replies
When I register my addins as an external command, they are appeared in the External tools list. I use them from Pushbuttons. But I want hide them from External tools list. How can I do that?
Labels (3)
3 REPLIES 3
RPTHOMAS108
in reply to: nur91m
In the manifest file (.addin) change:
<AddIn Type="Command"> to <AddIn Type="Application">
A class in your assembly will have to also implement IExternalApplication or IExternalDBApplication.
IExternalApplication used to add items to the UI that reference your IExternalCommand
IExternalDBApplication used where no access to UI features are required or permitted.
ameer.mansourWAK8Y
in reply to: nur91m
use this tag VisibilityMode  in your add-in
<?xml version="1.0" encoding="utf-8" standalone="no"?>
<RevitAddIn>
    <Text>Loose Connectors</Text>
    <Description>List all unconnected Revit MEP connectors</Description>
    <VisibilityMode>NotVisibleInArchitecture</VisibilityMode>
    <VisibilityMode>NotVisibleInFamily</VisibilityMode>
    <VisibilityMode>NotVisibleInStructure</VisibilityMode>
    <VisibilityMode>NotVisibleWhenNoActiveDocument</VisibilityMode>
    <Assembly>C:\bin\LooseConnectors.dll</Assembly>
    <FullClassName>LooseConnectors.Command</FullClassName>
    <ClientId>fc508f72-84b2-4e82-942c-ad9ec07cbe4a</ClientId>
  </AddIn>
</RevitAddIn>
@Anonymous which is hide from ribbon tool bar also.
Forma Design Contest
Rail Community
