Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
how to Purge unused materials
10 REPLIES 10
Message 1 of 11
dhanait_ajay13
923 Views, 10 Replies
dhanait_ajay13
How to Purge Unused Materials?
I use Performance Adviser for purging but performance adviser  doesn't get unused materials.
10 REPLIES 10
Message 2 of 11
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @dhanait_ajay13 ,
Could you please try using the steps mentioned in the below link?
https://boostyourbim.wordpress.com/2016/10/21/purge-unused-materials-for-another-rtceur-api-wish/
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Naveen Kumar T
Message 3 of 11
dhanait_ajay13
@naveen.kumar.t  Thank you
Message 4 of 11
dhanait_ajay13
but unused imported categories still remain exist
Message 5 of 11
naveen.kumar.t
Autodesk Support
Autodesk Support
Could you please provide some more information?
Can you explain your issue using screenshots?
Naveen Kumar T
Naveen Kumar T
Message 6 of 11
dhanait_ajay13
not able to detect this imported categories
Message 7 of 11
naveen.kumar.t
Autodesk Support
Autodesk Support
Thanks for the screenshots.
Are you able to remove these imported categories in the Revit UI (without using the API) without any problems?
What steps did you follow?
I am checking with the Revit Engineering team for you.
Naveen Kumar T
Naveen Kumar T
Message 8 of 11
dhanait_ajay13
yes i am able to remove these imported categories in the Revit UI (without using the API) without any problems
Simply click on Purge menu button 2-3 times it remove all unuse items
but using API i am not able remove this
Message 9 of 11
naveen.kumar.t
Autodesk Support
Autodesk Support
I had a discussion with the Revit Engineering team.
iterate through all categories. skip the built-in ones. pick Top level category with non-negative id. those are the ones you want. call Delete on those. I am not sure, though.
Also, Please take a look at these below links
https://thebuildingcoder.typepad.com/blog/2022/02/purge-unused-and-etransmit-for-da4r.html
https://thebuildingcoder.typepad.com/blog/2022/03/purge-unused-and-the-autodesk-camel.html
Naveen Kumar T
Naveen Kumar T
Message 10 of 11
skandregula
Hi Naveen,
thanks for sharing the link. I was able to use it successfully. However, I did see that it doesn't purge everything material related all at once. Is there a way we can modify that and ensure that it's done in one step?
Hi Naveen,
Message 11 of 11
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @skandregula ,
Sorry, I am not aware of any other ways to achieve this functionality.
Naveen Kumar T
Hi @skandregula ,
Naveen Kumar T
