how to Purge unused materials
dhanait_ajay13
dhanait_ajay13
How to Purge Unused Materials?
I use Performance Adviser for purging but performance adviser  doesn't get unused materials.
Replies (10)
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @dhanait_ajay13 ,
Could you please try using the steps mentioned in the below link?
https://boostyourbim.wordpress.com/2016/10/21/purge-unused-materials-for-another-rtceur-api-wish/
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
dhanait_ajay13
@naveen.kumar.t  Thank you
dhanait_ajay13
but unused imported categories still remain exist
naveen.kumar.t
Autodesk Support
Autodesk Support
Could you please provide some more information?
Can you explain your issue using screenshots?
Naveen Kumar T
dhanait_ajay13
not able to detect this imported categories
naveen.kumar.t
Autodesk Support
Autodesk Support
Thanks for the screenshots.
Are you able to remove these imported categories in the Revit UI (without using the API) without any problems?
What steps did you follow?
I am checking with the Revit Engineering team for you.
Naveen Kumar T
dhanait_ajay13
yes i am able to remove these imported categories in the Revit UI (without using the API) without any problems
Simply click on Purge menu button 2-3 times it remove all unuse items
but using API i am not able remove this
naveen.kumar.t
Autodesk Support
Autodesk Support
I had a discussion with the Revit Engineering team.
iterate through all categories. skip the built-in ones. pick Top level category with non-negative id. those are the ones you want. call Delete on those. I am not sure, though.
Also, Please take a look at these below links
https://thebuildingcoder.typepad.com/blog/2022/02/purge-unused-and-etransmit-for-da4r.html
https://thebuildingcoder.typepad.com/blog/2022/03/purge-unused-and-the-autodesk-camel.html
Naveen Kumar T
skandregula
Hi Naveen,
thanks for sharing the link. I was able to use it successfully. However, I did see that it doesn't purge everything material related all at once. Is there a way we can modify that and ensure that it's done in one step?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @skandregula ,
Sorry, I am not aware of any other ways to achieve this functionality.
Naveen Kumar T
