How to pass arguments from ribbon elemnts to function (commad class)
sai.yashwanthkumar
sai.yashwanthkumar
I have 2 push buttons which will do execute same functions but but with diff set of variables should be passed to the function on clicking on the push buttopns
for examples i have 2 push buttons to show/hide elemts in revit drawing, i will be managing the hide/show in one function(command class) if i click on show push button it should pass the parameter show to the function.
is there any way to do this in revit.
Thanks in advance.
/yashwnath
RPTHOMAS108
No that is the wrong approach for the external commands.
You provide class name when creating the button to point to an Implementation of IExternalCommand.  So when execute executes on that interface you don't know from what button that came, this is the issue.
You have to create a class for each command but with inheritance this can be very minimal e.g.
Imports Autodesk.Revit.DB
Imports Autodesk.Revit.UI
Public MustInherit Class RT_ExternalCommandsBase
    Implements IExternalCommand
    Public ReadOnly Property MethodName As String
        Get
            Return Me.GetType.Name
        End Get
    End Property
    Public Function MainExecute(CMDName As String, commandData As ExternalCommandData, ByRef message As String, elements As ElementSet) As Result
        Select Case CMDName
            Case "CMD1"
                TaskDialog.Show("Title", CMDName)
            Case "CMD2"
            Case Else
        End Select
    End Function
    Public Function Execute(commandData As ExternalCommandData, ByRef message As String, elements As ElementSet) As Result Implements IExternalCommand.Execute
        Return MainExecute(Me.MethodName, commandData, message, elements)
    End Function
End Class
<Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)>
<Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)>
Public Class CMD1
    Inherits RT_ExternalCommandsBase
End Class
Public Class CMD2
End Class
Public Class CMD3
End Class
sai.yashwanthkumar
It works thank you .. 🙂
