No that is the wrong approach for the external commands.
You provide class name when creating the button to point to an Implementation of IExternalCommand. So when execute executes on that interface you don't know from what button that came, this is the issue.
You have to create a class for each command but with inheritance this can be very minimal e.g.
Imports Autodesk.Revit.DB
Imports Autodesk.Revit.UI
Public MustInherit Class RT_ExternalCommandsBase
Implements IExternalCommand
Public ReadOnly Property MethodName As String
Get
Return Me.GetType.Name
End Get
End Property
Public Function MainExecute(CMDName As String, commandData As ExternalCommandData, ByRef message As String, elements As ElementSet) As Result
Select Case CMDName
Case "CMD1"
TaskDialog.Show("Title", CMDName)
Case "CMD2"
Case Else
End Select
End Function
Public Function Execute(commandData As ExternalCommandData, ByRef message As String, elements As ElementSet) As Result Implements IExternalCommand.Execute
Return MainExecute(Me.MethodName, commandData, message, elements)
End Function
End Class
<Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)>
<Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)>
Public Class CMD1
Inherits RT_ExternalCommandsBase
End Class
Public Class CMD2
End Class
Public Class CMD3
End Class
