BIM secondary development of beginners for the first time to write filter, select the wall instance, compile no problem, but run in Revit without any reaction, consult you!
The code wants to filter and select wall instances in Revit. The following is the code part:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.UI;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.UI.Selection;
namespace Element filter
[Transaction(TransactionMode.Manual)]
public class Class1 : IExternalCommand
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
UIDocument uidoc = commandData.Application.ActiveUIDocument;
Document doc = uidoc.Document;
FilteredElementCollector wallTypeCollector1 = new FilteredElementCollector(doc);
ElementFilter filter = new ElementCategoryFilter(BuiltInCategory.OST_Walls);
wallTypeCollector1.OfClass(typeof(Wall)).WherePasses(filter);
IList<ElementId> elId = new List<ElementId>();
int im = 0;
foreach (Element el in wallTypeCollector1)
elId.Add(el.Id);
im = im + 1;
uidoc.Selection.SetElementIds(elId);
return Result.Succeeded;
