How to move the tags with gven distance in Revit API
Pravin_Lande
Pravin_Lande
We have some Casework tags in file, we want to move the tags by giving some X and Y offset values. Kindly suggest how can we achieve this by adding given X and Y values in TagHeadPosition.
Thank you.
Pravin
jeremytammik
Dear Pravin,
Thank you for your query and for raising it here in the discussion forum.
If you search this forum for 'move tag', you will find a large number of earlier discussions regarding this topic.
The first one in the list I see seems to answer your question in full:
https://forums.autodesk.com/t5/revit-api-forum/move-tags/m-p/4372783
However, there are many more to look at as well.
The Building Coder also discusses this topic, briefly, offering a similar suggestion:
https://thebuildingcoder.typepad.com/blog/2013/10/move-tag-to-host-location.html
I hope this helps.
Please do search for existing answers before submitting a new thread.
Thank you!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Kevin.Bell
I would suggest using ElementTransformUtils.MoveElement:
https://www.revitapidocs.com/2016/781ad017-5ee5-f44b-5db2-e8e1f883ae5d.htm
Kevin.
