Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
How to load our own dll written with the revit api in the RevitPythonShell
2 REPLIES 2
995 Views, 2 Replies
I have written a dll with the revit Api.
There a simple function doSomethingToAElement
I want to use this function on a element
I have written
import clr  # OK
... clr.AddReference('C:\\Users\\user040\\Project\\myDll.dll')
And I have this problem
Exception : System.IO.FileLoadException: The given assembly name or codebase was invalid. (Exception from HRESULT: 0x80131047)
   at System.Reflection.AssemblyName.nInit(RuntimeAssembly& assembly, Boolean forIntrospection, Boolean raiseResolveEvent)
   at System.Reflection.AssemblyName..ctor(String assemblyName)
   at System.Reflection.Assembly.LoadWithPartialName(String partialName)
   at IronPython.Runtime.ClrModule.LoadAssemblyByPartialName(String name)
   at IronPython.Runtime.ClrModule.AddReference(CodeContext context, String name)
   at IronPython.Runtime.ClrModule.AddReference(CodeContext context, Object[] references)
   at Microsoft.Scripting.Interpreter.ActionCallInstruction`2.Run(InterpretedFrame frame)
   at Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame)
   at Microsoft.Scripting.Interpreter.LightLambda.Run4[T0,T1,T2,T3,TRet](T0 arg0, T1 arg1, T2 arg2, T3 arg3)
   at System.Dynamic.UpdateDelegates.UpdateAndExecute3[T0,T1,T2,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2)
   at Microsoft.Scripting.Interpreter.DynamicInstruction`4.Run(InterpretedFrame frame)
   at Microsoft.Scripting.Interpreter.LightLambda.Run2[T0,T1,TRet](T0 arg0, T1 arg1)
   at IronPython.Compiler.PythonScriptCode.RunWorker(CodeContext ctx)
   at Microsoft.Scripting.Hosting.ScriptSource.Execute(ScriptScope scope)
   at Microsoft.Scripting.Hosting.ScriptSource.ExecuteAndWrap(ScriptScope scope, ObjectHandle& exception)
Though this dll has compiled and is used already used for revit addin.
2 REPLIES 2
jeremy_tammik
Maybe this message is trying to tell you:
"The assembly you are attempting to load is referencing some other assembly and has trouble resolving that reference."
What assemblies does myDll.dll reference?
Jeremy Tammik, Developer Advocacy and Support, The Building Coder, Autodesk Developer Network, ADN Open
in reply to: jeremy_tammik
I replace AddReference with AddReferenceToFileAndPath. Now its working.
Thanks for you help
Forma Design Contest
Rail Community
