How to hide other elements when highlighting an element?
Hi, everyone! When I highlight an element, I want to hide other elements, how can I do this after I enter these codes?
ICollection<ElementId> ids = new List<ElementId>();
ids.Add(elem.Id);
UIDocument uiDoc = new UIDocument(elem.Document);
uiDoc.Selection.SetElementIds(ids);
uiDoc.ShowElements(ids);
Thank you in advance:)
RPTHOMAS108
Best way is probably to use temporary view mode with element isolation (cyan border which is activated in the UI with the glasses button).
In the API it is set on the view as below:
View.IsolateElementsTemporary(IDs as ICollection(Of ElementID))
To disable mode you use:
View.DisableTemporaryViewMode(TemporaryViewMode.TemporaryHideIsolate)
To make the visibility settings permanent you use:
View.ConvertTemporaryHideIsolateToPermanent
Thank you! 🙂
